Thread: Correct Crush Washers?
Created on: 04/12/17 07:42 PM
BobZ
BobZ's Gravatar
04/12/17 7:42 PM
Are these the correct ones to use? I have a 2014 but I assume they are all the same:
https://www.amazon.com/gp/product/B00K3B595M/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Thanks in advance...Bob Z.
Ride safe, but fast.
RE: Correct Crush Washers?
04/12/17 11:06 PM
Question: What are the dimensions of the crush washer, in inches or millimeters?
Answer: 14X22.3 mm
That looks about right. I have a couple OEMs out in the car but I can't get out to measure them right now.
Any aluminum washer will work as long as it's got a big enough ID to fit over the threads and small enough to fit under the flange of the plug. The washer I got with my aftermarket plug is very small but the hole is big enough for the threads to fit through.
* Last updated by: Rook on 4/12/2017 @ 11:07 PM *
BobZ
BobZ's Gravatar
04/13/17 6:43 AM
I could not find out the correct ID & OD of the Kawasaki Part# for the crush washer and my wife needed me to buy something so she could get free Amazon shipping so I figured those would work, but I am still not sure so if someone has the exact sizes please let me, and everyone else that changes them, know.
04/13/17 5:20 PM
I have some and they are 22 OD x 12 ID. A couple extra mm bigger hole is not going to matter. That will allow you to use the gasket as many times as you want without having it get squashed onto the threads.
I've been using the same gasket for several years. I go with 15 ft lbs on the plug and the gasket never expands but it seals fine, the threads in the drain port don't get worn and the plug never gets loose.
BobZ
BobZ's Gravatar
04/13/17 5:24 PM
Thanks, the ones on Amazon are 22mm OD by 14mm ID so about 5/64ths larger ID, which I agree will work.
* Last updated by: BobZ on 4/13/2017 @ 5:25 PM *
04/13/17 7:30 PM
Order the copper ones.
Even better buy an assortment box of copper washers in "mm" sizes.
So you have supply for oil plug, coolant plugs and brake components on hand.
04/13/17 8:29 PM
Honda car drain plug washer = same... cheaper.
BobZ
BobZ's Gravatar
04/14/17 7:26 AM
The Honda part# appears to be 94109-14000 and they have a 22mm OD & 14mm ID. The stock ones have an 12mm ID so while not the same they will work as others have stated.
* Last updated by: BobZ on 4/14/2017 @ 7:26 AM *
